Although the default language is German and the installation language was left to German the Uninstall process starts always in English when running it from Control Panel. How can this be prevented?
best regards
pfennig
Uninstalling from Control Panel always starts in English
pfennig
Happy New Year!
Thank you for your suggestions. Setting the LANGUAGE variable didn't help, though.
When I use the Setup file to uninstall then all dialogs are in German from the start. But using Control Panel the Maintenance and all following forms have English strings. OTOH, the shared dialog texts are correctly displayed in German.
best regards
pfennig
best regards
pfennig
I can't reproduce this either.
My localized setups all start with German language in maintenance mode.
Please verify:
- There are one or more directories under c:\\document and settings\\all users\\application data\\{GUID}
- Look for the directory which includes files with your product name
- In my setups I have a file called <product>.lan. Check if you have this file. In my setup the contents of this file is "German". This file is created at install time.
Please verify:
pfennig
Thank you. I've got it to work now. The reason seems to have been a workaround that I created to compensate the fact that the string that is put into the field "Product Name" is actually the value for the TITLE variable, which is used all over the place. The get a little more flexibility I created a new variable that really holds the product name and assigned it combined with the company name to TITLE, like this:Tinus wrote:I can't reproduce this either.
Set Persistent Variable PRODUCTNAME to $TITLE$
Set Variable TITLE to $COMPANY$ $PRODUCTNAME$Anyway, I think it would be great if, in a future version of InstallAware, a few more variables could be set via the fields that are there, and the names of the fields would fit to the names of the variables
best regards
pfennig
