InstallAware floating license question
mkelley
Post by mkelley »
What are the requirements for supporting floating licenses? Do you use Flex/LM or some other license manager that would be installed on a PC somewhere on our network? Can a license be temporarily reserved for operation while disconnected from the network. For example, at customer sites I sometimes make custom modification that I want to work into the install program to leave with our customer. Many of these locations do not have Internet network connectivity.
Post by CandiceJones »
No license managers or servers are required at any time! You will be able to use the floating license free from artificial hindrances of any kind.
