This new plug-in provides an alternate connection method to Microsoft SQL Server databases. Some users have been reporting issues with the standard InstallAware methods used for running scripts on Microsoft SQL Server databases. This plug-in provides an alternate connection method:
Installation:
Download and run www.installaware.com/clients/Alternate_SQL_Plug-In.exe
License:
Free for all trial and licensed InstallAware users.
Usage:
The plug-in provides a new MSIcode command, Alternate SQL Server. Simply enter this command and populate the command fields (which are very similar to the native InstallAware fields).
Notes:
You must provide the path to a pre-existing SQL script at compile time. The script may be stored as ANSI or UNICODE (the native InstallAware method did not support UNICODE), and contain MSIcode variables.
New Plug-In: Alternate SQL Server
Results from Alternate SQL Plugin Test
Hello Candice,
Michael made me aware of this plugin during the Christmas holidays because I have had no success getting IA's native 'Standard' SQL Database Server Configuration to work with my SQL script.
I have been testing with this new 'Alternate SQL Plugin' for most of this week, and I'm sorry to say that I have had no success in creating a database.
I have created a stripped down installation that does nothing more than to install SQL Express and the attempt to create the DB based on my script file.
I am hoping that you or Michael might be able to help me figure out what is going on by having a look at my stripped down IA project. I must be doing something wrong, but after a month now of no success, I am hoping that some 'hands-on' work by the IA Support group might resolve this problem both to my benefit and those other IA users that have been struggling with this as well.
Thanks very much
Steve
Thanks very much
Steve
Steve,
I have just finished extensive testing of the new SQL Server plugin that is included in versino 6.14 which is available for download now.
Please download this and install it.
THis is not the Alternate but the Main SQL Server Plugin.
Split you script into 2 parts,
First part is the create database with all the settings for the Database and runs against the master database. Make sure you have no line wrapping.
The second part is all your create tables, create defaults, create procedures and functions, etc. and runs against the name of the database that was created in the first script.
Give this a try and let me know, also if you can email or post the SQL Scripts and I will be more than happy to work through this with you.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Users browsing this forum: No registered users and 83 guests
