Problem running exe file at end of install
David Le Mesurier
Post by David Le Mesurier »
I want to run a small visual foxpro exe at the end of teh installation process.
This works OK, but the exe although installed in the targetdir thinks it's in the temp directory that the isnatll process seems to be running from.
How do you tell it to run in the targetdir?
David Le Mesurier
OK Sorted.
Used the Run Program AS command rather than the Run Program command
