I'm trying to uninstall version 6 under Vista Business Rtm.
When starting the uninstall I get the following error:
Runtime Error in script:
Line 17: Attempting to get value of undefined variable UPDATE_CONFIGURED
How can I uninstall Installaware?
Thx,
Bernaert Dominique
Can't uninstall under vista rtm
Unfortunately 6.1x prior to 6.13 was a broken build and exhibited these issues. I do apologize for the inconvenience.
To fix, please follow these steps:
1) Search your hard disk for the file:
myahe.dat
2) Add the following lines at the end of this file:
So the end of the file looks like:
3) Uninstall
Then, please install the latest 6.13 build from the public website. Again,
I apologize for the problems the broken build caused you. 6.13 works very
well (this is not a Vista issue but affected all OS versions).
myahe.dat
UPDATE_CONFIGURED
TRUECode: Select all
UPDATE_CONFIGURED
TRUE
UPDATE_DOWNLOAD
TRUE
UPDATE_INSTALL
FALSE
UPDATE_AUTO
FALSE
...Then, please install the latest 6.13 build from the public website. Again,
