What is the latest build of InstallAware
darnold@coderocks.com
Postby darnold@coderocks.com » Mon Jan 08, 2007 1:29 am
The about box shows the latest build I have, but I can't find the latesst release build on the web site.
My laptop install is a later build than my desktop install. Both are running the same OS (Vista Ultimate)
I have no confidence in the hidden application updater.
Any suggestions?
Dan Arnold
jimo
Postby jimo » Mon Jan 08, 2007 8:06 am
Go to the downloads page on the main website and you will see that the lates build is 6.13.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Installaware Build ???
Postby darnold@coderocks.com » Mon Jan 08, 2007 8:29 am
I need the latest build number
for example:
My desktop computer is at Version 6.13 (Build cambridge_sp3.1407)
My laptop is at Veriosn 6.13 (Build ?_sp4.######)
Dan Arnold
jimo
Postby jimo » Mon Jan 08, 2007 9:11 am
I would try applying your license file to your laptop so that it reads Version 6.13 (Build cambridge_sp3.1407).
Go to myinstallawre.com, login and regenerate your license file and run it on your laptop and see if that does not correct the problem.
Jim Oswell
Postby MichaelNesmith » Mon Jan 08, 2007 12:42 pm
We do not have a "Veriosn 6.13 (Build ?_sp4.######)" build - did you have a screenshot available to show us how you got this number?
How do I force an update?
Postby darnold@coderocks.com » Mon Jan 08, 2007 9:38 pm
Regarding --
I didnt mean that build number literally.
It turns out that my laptop is at version 6.0 sp4
I do not leave it running 24x7. How do I force an update?
Dan Arnold
Tinus
Postby Tinus » Tue Jan 09, 2007 4:08 am
Download the latest version from here:
http://www.installaware.com/downloads-p ... nloads.htm
Then go to http://www.myinstallaware.com
recreate your license file, download and install.
Martin Rothschink
AxoNet Software GmbH
File Extension Problem
Postby darnold@coderocks.com » Tue Jan 09, 2007 12:40 pm
It turns out that my web server was not allowing the .7zip file extension to be accessed. I renamed the files to *.bin rebuilt the setup and everything worked fine.
Dan Arnold
Users browsing this forum: No registered users and 36 guests
