Error with Crystal Report Merge Module - Access2003_enu
Linuxman
Postby Linuxman » Sat Jun 04, 2005 8:38 pm
I am receiving the following error when trying to merge the Crystal Report Merge Modules for deployment. This is the only one doing this. The remaining one are fine.
Error during build: Unable to merge Windows Installer database with
module Crystal_Database_Access2003_enu
sinan
Postby sinan » Sun Jun 05, 2005 2:47 pm
An update for the InstallAware merge module mechanism is available.
Please download the file http://www.installaware.com/mmergemod.dll and place it in your InstallAware folder, overwriting the old copy. Then try again.
Be sure the IDE is closed before you attempt to overwrite the file.
Linuxman
Postby Linuxman » Sun Jun 05, 2005 5:39 pm
This took care of the issue. Is there some location on your site where I should be searching for updates. We are still using the trial, but I want to make sure we are successful with an installation before it runs out, then we plan to purchase. We still have some errors we are trying to work through.
sinan
Postby sinan » Sun Jun 05, 2005 7:02 pm
This is the only current update that is available for InstallAware 2005.
You may check the Plug-In, Sample Script, and New Theme forums for updates, but they do not contain material that is new for InstallAware 2005 - only newer versions.
Let us know if there is anything we can help with, regarding your errors.
Users browsing this forum: No registered users and 40 guests
