How can I disable 'Simple File Sharing' in Windows?
Steve
Post by Steve »
Hello all;
I am encountering some uninstall problems that appear to be caused by Windows default 'Use Simple File Sharing' option (that is turned on in all Windows 2000 and XP installs by default).
I am wondering if anyone has any experience with how to turn off Windows 'Simple File Sharing' mode while performing an IA install?
Thanks in advance
Steve
Tinus
Post by Tinus »
A quick search in Google gives this result:
HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Control\\Lsa
Look for the value ForceGuest. 0 turns off Simple File Sharing, 1 turns it on.
I have not verified this myself...
Martin Rothschink
AxoNet Software GmbH
Steve
Post by Steve »
Thanks very much Martin.
I'll give this a try and post my results.
Steve
