How to check/Install IIS server.
mazharnazeer
Post by mazharnazeer »
I need to check/Install IIS server as setup prerequisite.
I am using InstallAware 6 at Windows 2000 Server along with SQL Server 2005 Express Edition and .NET Framework 2.0 support.
Second query is, when i build the setup with best compression or fair compression then InstallAware gives error of low memory.
Thanks in advance.
1. This is not allowed by Microsoft - you cannot redistribute or install IIS. Of course, you can use PackageAware and attempt to capture the resulting setup and then convert that into a prereq, but this would probably be illegal.
2. Install more memory on your computer.
