hi,
Iam using the demo version of 'InstallAware'. And Version No6.0
I need to create a setup file for VisualBasic 6.0 .
Iam having a folder named 'Photos' which contains some 20 subfolders and each subfolder contains avrage of 20 subfolders. here each folder contains some 40-50 images.
I Build the Project under the uncompressed mode. So that it can be distributed on CD/DVD.
After building the project if i want to change/replace an image in any folder...,
is there any option for that ? that to with out re compiling is possible?
means it has to accept the modifiaction/changes done.
Please Give Me Suggestions
Modifying Files/Folders After Building The Projet
You can do so using the Copy/Move Local Files command, or the Call DLL Function command by way of calling CopyFileA/MoveFileA in kernel32.dll.
Users browsing this forum: No registered users and 72 guests
