Is there an easy way to enforce a minimum number of characters that can be entered in a field before moving on to the next dialog? We have a registration number in the form
XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
I can set a MaxLength of 29 characters on the text field to ensure that it is not too long, but if it's too short I'd like a message box to pop up and say something like "Serial number is not long enough. Please check your typing and re-enter." (OK, something a bit more polite than that, but you get the idea.)
I have seen other posts that mention either creating a plug-in or calling an external DLL, but this seems like overkill for my needs - is there a "string length " call somewhere I could make?
Eric
Serial # - Enforcing minimum number of characters typed in
Update: I tried calling the kernel32.dll function lstrlenA to get the string length, but it didn't work; I got the error "Unable to load plug-in library. Please rebuild your project and make sure all required plug-ins are installed. Action skipped." I suspect this is because I don't have all of the parameters for the Call DLL Function set up exactly right.
Here is the call I'm making in clipboard form:
~InstallAware Clipboard Data~
~Call DLL Function~
~{7D9B000F-F296-47BA-BE84-B47848AA8D70}~
~kernel32.dll,lstrlenA,long,SERIALNUMBERLENGTH,"allocated string buffer (MAX_PATH length)",$SERIALNUMBER$,$~
~~mIDEFunc.dll\\mEXEFunc.dll~ ~
Anyone have a clue on what's going wrong here?
Eric
~Call DLL Function~
Eric
Why don't you split it on X/Total Length textboxes?It's very easy to do it that way.. Look the example shipped with InstallAWARE.
Panagiotis Kefalidis
Software Design Team Lead
Users browsing this forum: No registered users and 81 guests
