How dynamic can InstallAware be?
jasonyau
Postby jasonyau » Fri Jan 26, 2007 4:40 pm
I would like to build an installer that packages the required directories dynamically.
For example, I have 200 examples store in corresponding directory EXAMPLE_XXX that I can cherry-pick to package in the installer. Let's say I like to package Example 10-30, 50-80, 120-150. Is there a way for me to specify the choice effectively through maybe the compiler variables?
Thanks!
Postby MichaelNesmith » Sat Jan 27, 2007 4:00 pm
Well, you can selectively include/exclude files by compiler variable values, but you do need to code this in the script.
Additionally, you can use compiler variable values to populate file and folder fields at build time - selectively including/excluding wildcards, specific folders, etc.
But if you just have 200 random folders with no shared/discernable characteristics, it seems like a manual job either way.
jasonyau
Postby jasonyau » Mon Jan 29, 2007 12:22 pm
Hi Michael,
Can you take the example I provided and suggest some compiler variables and the corresponding script that can effectively manage this?
I hope defining 200 compiler variables like TAKE_EXAMPLE_001 .... TAKE_EXAMPLE_200 to select folders is not the only solution.
THANKS!
Postby MichaelNesmith » Tue Jan 30, 2007 11:05 pm
Like I already said, if your files have no common patterns to discern them, then yes, that is the only tedious way.
jasonyau
Postby jasonyau » Wed Jan 31, 2007 3:53 pm
Can I list the directory names that I want to package into a file (maybe XML)? Pass the path of the file as a compiler variable, and have InstallAware go through this file to call Install File on each item?
Postby MichaelNesmith » Wed Jan 31, 2007 4:51 pm
Sorry, that's not possible. You can use, if you want, the automation interface, to programmatically emit setup scripts. Maybe this is what you need.
mmiron
Post subject: How dynamic can InstallAware be?
Postby mmiron » Fri May 25, 2007 2:09 pm
What about externally modifying the IA script so that the Install statements are dynamically generated?
The problem we are having is that we need a way to dynamically create the install list that IA will compile with.
Example line that would be dynamically "imported" into the main install script for the compile:
Install Files #SOURCEDIR#\\myFile.xml to $TARGETDIR$\\myFile.xml, include subfolders
Does InstallAware support this?
SteveX
Automation
Postby SteveX » Sat May 26, 2007 2:00 pm
What you are asking can be done with the automation interface. It is actually even more versatile and is scriptable via the web or within your own program. That basically means you can create and build an entire installation outside of the IA UI. What you can do with it is only limited by your imagination.
That was one of the main reasons I purchased the full blown version as I needed two things...
Dynamically generated installations built from information a user enters on the web.
A way for my users to generate an installation program to redistribute graphic design templates created in my program.
Quite pleased with the results, besides a few little quirks here and there.
mmiron
documentation...
Postby mmiron » Wed May 30, 2007 12:42 pm
I've looked at the automation interface, and honestly the only function that stands out is the addCommand. But it has ~23 non-named parameters that can be used to help define the command added.
Now i've tried reseaching the different commands and their respective parameters but i'm ending up short on that - anyone have a url(s) or information on that?
Is there no way for the AI to load a template script up and have the ability to modify it once loaded?
SteveX - you are right this looks like the only solution to my problem but i'm lacking documenation that would help me get up and running quickly.
I appreciate any help or comments -
Cheers,
Marc.
Users browsing this forum: No registered users and 76 guests
