I'm calling a function in a DLL that I wrote that depends on several other DLLs. I can get the installer to work by manually copying these DLLs into the same directory as the setup executable. I want to know how to automatically include these DLLs in the project so that I do not have to copy them after every time I recompile the project. I attempted putting them in the Support Files, but that did not help. I found no help in the documentation either.
If you manually copied the DLL in the project folder, that won't work. You will want to add the DLL, and all its dependencies, as Support Files (called Creatives in the visual view). And then load the DLL using the $SUPPORTDIR$ path.
