variables containing empty strings in text boxes
Will
Postby Will » Thu Jun 23, 2005 5:45 pm
When I put a variable in a text box and taht variable contains an empty string, instead of removing the variable from the text, it displays $VARNAME$. How do i make it display an empty string instead of the name of the variable?
sinan
Postby sinan » Thu Jun 23, 2005 7:27 pm
Indeed, this appears to be a bug. Thank you for reporting it!
A temporary workaround could be to leave the text box empty, but still setting it to write to the variable. Or, to set the variable value to space.
Return to “Non-Technical”
Users browsing this forum: No registered users and 43 guests
