Defining a registry key, why is the option not present ?
Pete B
Postby Pete B » Wed Jan 31, 2007 12:00 pm
Hello
I wanted to do the simplest of things yet still the wheels have come off ;-)
Visual view, Registry, Feature independent (box checked). I want to define a new key in : HKLM/Software/Microsoft/Windows/Currentversion/App Paths. I navigate to this in source keys. When I right click on 'App Paths' I don't get a new key option only an option to refresh views.
What am I doing wrong here ! I've gone through the help file instructions 3 times but no joy.
It would probably be just as easy to 'Write Registry' in MSI code view but this is the first key I've ever tried to define and I want to see where IA inserts it into the script.
Thanks and best wishes
Pete B.
Postby MichaelNesmith » Wed Jan 31, 2007 1:09 pm
The top (local machine) browsers are for browsing the local machine so you can "copy" existing keys to your local machine.
To create a "brand new key", use the bottom (target machine) browsers. Just right click any node and select New Key - then you can type in a full key path.
Pete B
Postby Pete B » Wed Jan 31, 2007 1:43 pm
:oops: Sorry you had to waste time on that one Michael. Your 1500th post should have been for something a little more 'appetising' than that !
thanks and best wishes
Postby MichaelNesmith » Wed Jan 31, 2007 2:24 pm
Oh wow! Didn't realize I was up to 1500 :)
Users browsing this forum: No registered users and 65 guests
