I just started with InstallAware. I created project in a new folder. Now there are many files in there... dll's for the .net frameworks, etc. I want to back the project up into our source code repository. What files need to archived. My goal is to only archive the files that contain my project specific information and I'm ok w/ allowing InstallAware to rebuild media block dlls and other content like that.
Thanks!
What files in a project folder need to be archived?
First, no need to archive anything in subfolders (unless you explicitly use those files, from #PROJDIR#).
Next:
You can directly ignore all the DLL files - these are temporary files copied over while building and working in the IDE.
Other files optional for saving are:
Next:
- <project>.mpr - Main project file
*.mia - Script files
*.dfm - Dialog files
*.dfm.miaf - Dialog rule files
updates.ini - Update information file
- *.mia.brk - Breakpoint files
*.mia.fld - Code folding files
Thank you!
This is just what I was looking for. If it was in the help, I could not find it. If not, it might be worth a page.
Thanks for the info.
