As far as I know InstallAware has no option to build merge modules.
I have a set of components that needs to be included in a lot of setups. They are not just files but require custom registry settings and registration.
What is the best way to package these components without copying the script source to every setup?
Will you add merge module support in the future?
Thanks!
Building merge modules?
There are several ways this can be addressed: by using include scripts, merge module support, or light-mode setups.
Light mode setups have already been implemented and will be available with the next update to InstallAware. They are InstallAware setups that exclude the runtime, and designed to be invoked from another "master" InstallAware setup.
Users browsing this forum: No registered users and 96 guests
