I have IA Developer and I created a Install Kit single compressed file for a database app.
Now, I modified the app (no database file is affected) and I want to create a new kit that is able to update the app but leave the database file unaffected (the database is a directory with many files - something like an foxpro or paradox app).
Is posible that?
update for a database app
I think you want to mark the files as permanent in your original install (and manually delete them using Delete Files Recursive after an Apply Uninstall - this way they will be removed only when doing a manual uninstall but never during an auto-upgrade new install scenario).
If that is not possible any longer, I would build a patch for the original install, after taking out the references to the database files in the latest setup project.
i.e. my database files will be never affected by a new version?
Great. How can do this?
I searched in the help/contents and I found nothing about "mark the files as permanent"
Switch to visual view, double click the "Install Files" command. At the bottom are the Copy Options.i.e. my database files will be never affected by a new version?
Another approach (if your application is already in use):
Rename the database directory before you do an auto-upgrade. Then rename back. This should be done in the
[DEFINE REGION: Install Application Pre-Requisites]region before and after
Install/Remove MSI Package $OLDPRODCODE$[REMOVE=ALL] (get result into variable REMOVEOLD)
I'm beginer with IA and I not understood your adviceTinus wrote:Switch to visual view, double click the "Install Files" command. At the bottom are the Copy Options.
Rename the database directory before you do an auto-upgrade. Then rename back. This should be done in theCode: Select all
region before and afterCode: Select all
how i can rename the database directory
Please give me an example and, if is posible, tell me where I can foun a manual about scripting
