Mixed Architecture Installers and WriteRegistry
H4nd0
Post by H4nd0 »
Michael,
Our product is comprised of .NET and X86 components. I target the NGEN based on architecture.
The issue I'm facing is that once I set the install into 64-bit mode, attempts to change mode don't appear to work, or registry writes are not vectored correctly.
For example if I:
Write Registry Key HKLM\\SOFTWARE\\FireDaemon Technologies\\FireDaemon\\2.0\\Product, Trinity
Only one registry key is created. No registry key is created under Wow6432Node.
If I try this instead:
Write Registry Key HKLM\\SOFTWARE\\Wow6432Node\\FireDaemon Technologies\\FireDaemon\\2.0\\Product, Trinity
The latter register key is still not created.
Any advice on how to work around this greatly appreciated.
Because Write Registry commands are applied only when Apply Install is called (same as all other Windows Installer commands used in your script - these are highlighted in purple to make them easy to identify, please read the "Classes of Commands" section in help for more information), your approach of using the Set 64 bit Mode command in between calls to Write Registry will not work, unfortunately.
It would work well when reading, but not when writing.
You can try the native write registry plug-in and that should help. Because it will write directly by-passing Windows Installer, it should not be subject to these limitations.
