optional folder
jasonyau
optional folder
Post by jasonyau »
I have an optional folder that may exist and I am making Install Files call with this folder. I got Build failed if this folder does not exist. Is there a way for me to check the existence of this folder in the script before I call Install Files on it.
There is a Does File/Folder exist command but it only works in target system.
Yes, I think the only way would be with compiler variables for you to manually include/exclude the folder. Sorry!
