I create few groups of shortcuts to scripts. Shortcuts are located at folders named according to rule:
$SHORTCUTFOLDER$\\[hostName]
In previous IA version it worked ok, now (6.24) only group of shortcuts for last host is created.
My installer started in repair mode allows to create shortcuts for another hosts. In this case only folder for last specified host is created without shortcuts.
I only upgraded IA!
Shortcuts not created after upgrade to 6.24
Can you provide a minimum setup that illustrates this issue? This sounds like a bug and we will be happy to fix it for you.
If the problem exhibits with IA 6.24, you will need IA 6.24.
Users browsing this forum: No registered users and 104 guests
