Suggestion for next vers of InstallAware
BruceMcK
Post by BruceMcK »
I've got a suggestion for your next version. Currently the SQL Scripts area lists each script, but if you have a few in your install (I've typically got 6 or 8 individual scripts), there's no way of knowing which script is which, without actually opening the editor.
It would be good to be able to name each script (e.g., 'add db table', or 'insert preset values'), so that it becomes obvious what the purpose of each script is.
Thanks, Bruce.
