TargetDir variable problem
Doron
Postby Doron » Fri Feb 16, 2007 6:08 pm
Hi Mike,
I did not get any reply before so I am hoping that I can see something coming.<S>
I am trying to let the user to choose a different drive but still keep the installation folder. So I copied the Destination dialog to a new name and added a drop down list that will allow the user to select only a different drive.
For the Drop Down List I have the following:
The Receives Information says: Installation Folder
Write value to Variable is empty.
The Problem is that the TargetDir variable can not be updated via the combo box and it needs to be displayed into the Folder Text control where Enabled is False.
The strange thing that my friend is using the same dialog box with the combo and in his computer it works.
How can I make the TargetDir memvar to be updated when ever the combo box change the drive and not to loose the installation folder name?
Like to change the drive so it will be as: D:\\ABC9 and not only as D:\\
It works fine when ever I select Drive C via the combo and it is C:\\ABC9
To set up the TargetDir I do as follows:
SET Variable TARGETDIR TO $BootDrive$$MAIN_PROJECT_NAME$
Doron
jimo
Postby jimo » Mon Feb 19, 2007 4:54 pm
Doron,
I get exactly the same results you do, which is by design the way it is suppose to wrk, I would love to see the code from your friends script posted here.
Jim Oswell
Greenway Health, LLC
http://greenwaymedical.com
Edhy
Postby Edhy » Mon Feb 19, 2007 11:37 pm
Hi Jimo,
If this approach is by design, what would be the correct IA way to get this kind of feature where the Installation Folder is setup by default by the developer and the End User should only be able to change the Installation Drive?
Thanks!
Edhy Rijo
Edhy Rijo
Doron
TARGETDIR PROBLEM with Destination dialog box
Postby Doron » Wed Feb 21, 2007 12:47 pm
Hi Jim,
I have the same Destination dialog box that my friend has and even copied his project to my computer and running his project all works fine. So I was changing what ever possible based on his scrip and still it does not work on my project.
So I can not provide you a definite answer yet. I was hoping that InstallAware will provide such a basic feature build in since when I was using Wise Installation it was pretty easy to do. So why IA do not intervene in here???
Regards,
Doron
Immelman
Target dir checking
Postby Immelman » Tue Feb 27, 2007 5:25 am
Is it possible to check if the Target dir in the destination exists before continuing the installation?
If I enter an illegal file path in the destination dialog’s file path i.e. (non-existing file, file path with illegal chars %, $, &, etc.) the installation continues and to install the files to the program files directory on my computer.
If I delete the destination drive letter the setup also continues up and till the point where it gives me the following error: “Could not access network location: (Incorrect file path)”
I want the user to be able to type or browse to the installation destination of his/her choice. Then I want to check if the filename provided exits and is valid.
neillans
Postby neillans » Tue Feb 27, 2007 7:36 am
You can add validation routines as needed via MSI Code if you wish.
I'll see if I can add built-in validation to the wish list :)
Andy Neillans
Immelman
Example of validating MSI script
Postby Immelman » Tue Feb 27, 2007 8:32 am
Could you please give an example of path validating MSI script?
I was kind of hoping to insert the "Does file/ folder exist" into my MSI script but I dont know where to insert it so that the string value that gets inserted by the user into the textbox object on the destination dialog gets evaluated when the next button is clicked.
In my setup the only mention of the TARGETDIR variable in the MSI code is in the "Setup User Interview" Region.[/quote]
neillans
Postby neillans » Tue Feb 27, 2007 8:54 am
If you have a look through your script, you should have a section that includes
label: Destination Directory
If you add your validitation code in the following if block - for example:
Display Dialog: destination, wait for dialog to return (modal)
if Variable WIZARD Equals BACK
  GoTo Label: Custom Setup
  else
  if Variable WIZARD Equals CANCEL
    GoTo Label: Main Install
// Add your validation code here. If it fails, goto label Destination Directory.
So, something like this should do the job (untested!):
  else
  Set Variable TARGETEXISTS to FALSE
  Does Folder Exist $TARGETDIR$ (get result into variable TARGETEXISTS)
  if Variable TARGETEXISTS Equals FALSE
    GoTo Label: Destination Directory
Andy Neillans
Edhy
Re: TargetDir variable problem
Postby Edhy » Tue Feb 27, 2007 12:21 pm
Hi Andy Neillans
Glad to see someone from IA here.
How can we force an installation to install in a predifine folder like "MyApplicationFolder"" and just allow the user to change the drive?
Please take a look at the quote below for more info.
Doron wrote:Hi Mike,
Doron
Edhy Rijo
neillans
Postby neillans » Thu Mar 01, 2007 4:32 am
Sure :)
You would need to modify the "destination" dialog, and remove the text control (or make it readonly).
Drop a "DriveComboBox" from the Browser tab in the Dialog Editor, and set it to save the drive letter out to a variable.
Then, in your code, you would need to strip the drive letter of the original target path (before loading the dialog), and add the new target drive letter after the dialog closed.
That should do what you are after :)
If I get time, I will create an example project of this.
Andy Neillans
Edhy
Postby Edhy » Thu Mar 01, 2007 9:20 am
Hi Andy,
Thanks a lot for this info, I had try something like that.
I would really appreciate if you could take the time to drop me a sample code. :roll:
Edhy Rijo
neillans
Postby neillans » Thu Mar 01, 2007 4:47 pm
Have a look at the attached; hope it does what you are after :)
Install Drive.zip
Andy Neillans
Edhy
Postby Edhy » Fri Mar 02, 2007 12:17 am
Hi Andy,
Thanks a lot for taking the time to provide the sample code, it did help greatly.
I had to fix the TARGETDIR value with the selected drive from the combo, the original line153 is:
SET Variable TARGETDIR to $DRIVES\\$PATH$
And I changed to:
SET Variable TARGETDIR to $TARGETDRIVES\\$PATH$
Which is obviously a keyboard mistake, but the important thing is that your approach does work :D
Edhy Rijo
Users browsing this forum: No registered users and 17 guests
