pumagaju
Posts: 2 Joined: Wed Feb 21, 2007 3:09 pm
Post
by pumagaju » Wed Feb 21, 2007 3:23 pm
I have an InstallAware wrapped EXE that I need to deploy via Altiris. But I'm having trouble finding the switches to run in silent mode.
Also would like to know if I can easily enter license key info the same sorta way that InstallShield works with setup.iss files.
Thanks in advance,
H4nd0
Posts: 92 Joined: Thu Nov 09, 2006 8:16 am
Post
by H4nd0 » Thu Feb 22, 2007 7:28 am
In the IA 6.24 CHM help ... look for Setup Command Line Parameters:
/s
/l
/k
/p
Plus you can pass variables on the CLI which you could potentially use for your licensing.
pumagaju
Post
by pumagaju » Thu Feb 22, 2007 12:18 pm
Thanks for the pointer. I was able to use the logfile switch to create an initial logfile. Then I read the logfile to find the correct variable values I need to set, in this case LICENSE=.
