delete folder function, only possible with vb-script ?
emu99
Postby emu99 » Mon Feb 26, 2007 9:09 am
is there a possibility to remove complete folders ?
I can't find a function for deleting folders... like "delete files".
E.g. I need to delete a folder inside folder SHORTCUTFILES after a installation created a folder with links.
Since we don't want programs to create their own shortcuts on the clients uf our users, because we use a central shortcuts on a fileserver for which users are each permitted by Acitve Directory-Group...
The Installation itself is executed inside the project with the run program function, since no msi-package available of JDK 5.02 EE.
@Installaware: could be something for next version / Designrequest
Best Regards
Emu
emu99
workaround with vbs
Postby emu99 » Mon Feb 26, 2007 10:33 am
i managed to create a workaround with a vbs which can take a parameter which holds the path + foldername and added the vbs under supportfiles...
so now i call run program with $WINSYSDIR$\\cscript.exe and parameter $SUPPORTDIR$\\removefolder.vbs $WINSYSDIR$test (as e.g. to delete folder test inside system32)
But i wonder why a such often used function like deletefolder is not inside the regular functions of installaware. Or I'm just blind and can't find it :-)
removefolder.vbs:
On Error Resume Next
Set objArgs = WScript.Arguments
Set WshShell = WScript.CreateObject("WScript.Shell")
Set fso = WScript.CreateObject("Scripting.FileSystemObject")
fldr = objArgs(0)
If fso.FolderExists(fldr) Then
fso.DeleteFolder fldr, True
End If
Set fso = Nothing
Set WshShell = Nothing
Set fso = Nothing
WScript.Quit(0)
dmostert2
Postby dmostert2 » Tue May 15, 2007 4:07 am
Yes - I agree with you. It shouldn't be so difficult to remove a folder's contents and afterwards the folder as well :?:
Cheers,
D.
davidda
Postby davidda » Tue May 15, 2007 9:10 am
It isn't difficult. :P
Just use the Run Program function to run cmd with the parameters /C "rd /S /Q "c:\\DirToDelete""
dmostert2
Postby dmostert2 » Tue May 15, 2007 12:45 pm
:P Very clever - but will this work on Vista and UAC?
D.
Postby MichaelNesmith » Tue May 15, 2007 1:54 pm
Delete Files Recursive, anyone?
davidda
Postby davidda » Tue May 15, 2007 2:18 pm
Michael i don't think this would help, because they don't want to only delete the files in the folder, but the folder itself.
I don't know if it works on Vista or UAC (what's that?), because i have none of them here.
Postby MichaelNesmith » Tue May 15, 2007 2:37 pm
Use Call DLL Function on RemoveDirectoryA in kernel32.dll if you want to remove a folder that is already empty.
JohnGalt
Re: delete folder function, only possible with vb-script ?
Postby JohnGalt » Fri Sep 17, 2010 1:48 pm
There should be a script command for this. I know that Windows Installer does it, it's not hard there, so this is just an oversight! Please add this feature!
Postby mills » Fri Sep 17, 2010 7:34 pm
The request for this feature has been noted.
In the mean time, to delete a folder, you'll need to:
Delete the contents of the folder:
Recursively Delete Files $path$\folder
Delete the (empty) folder:
Call DLL Function kernel32.dll->RemoveDirectoryA
ckaware
Postby ckaware » Thu Dec 01, 2011 1:00 pm
What's the status on this feature request? I uninstall my application and the TOMCAT folder left behind has a ton of EMPTY sub directories.
giaviv
Postby giaviv » Thu Dec 01, 2011 7:36 pm
Chris,
For now, please use the workaround above.
John Mc
Postby John Mc » Tue Feb 14, 2012 6:53 pm
I appreciate the work around, but I'd like to check an alternate solution. Can you:
1) Recursively Delete Files "$path$\folder\*"
2) Recursively Delete Files "$path$\FileNameThatDoesNotExist.not"
Assumptions:
1) I want to delete all empty folders under $path$2) I'm confident that no files exist with the name given above
Thanks!
giaviv
Postby giaviv » Wed Feb 15, 2012 12:06 am
How about you give it a try? Which version of IA are you using?
John Mc
Postby John Mc » Wed Feb 15, 2012 12:53 pm
I tested it out and everything seemed to work fine. We'll see how things go in a more complex environment, but I'm happy enough to go with it.
I'm using IA 12 Studio on Win 7.
Users browsing this forum: No registered users and 49 guests
