I have about 7 features in the install. 3 or 4 of them rely on the same base set of components. What's the best way to handle this situation.
If I include them in each feature, is the build routine smart enough to know they are duplicates and not includes them multiple times? Or, do I need to handle this through script?
Thanks in advance.
I've very impressed with the product so far.
How to handle duplicate files
You can go ahead and define a hidden feature, and then manually manage the selection of that feature, based on the states of the user-visible features, from the script.
