Which SDK function will I run? COM Interop
GordonS
Post by GordonS »
I'm just evaluating InstallAware an amd quite encouraged.
I had a problem, though, on an install that might be related to what IA installs.
My COM interop stuff didn't register properly. I think from stuff I've read elsewhere in these fora that I need to run aegasm and gacutil after installation to do the COM Interop registration iton the GAC.
On the target I'm presently using, after installation, I had both command available, but regasm was from SDK v2.0 and gacutil eas from SDK v1.1. These two versions appear to be incompatible with each other and/or incompatible with VS2005 assemblies.
If I understand correctly, IA installs the SDK v2.0, however it appears to have _not_ installed gacutil v2.0.
Is there a means that I can ensure that I have the right and matching versions of regasm and gacutil installed?
Is it still true that I must run these command using the "Run Programs" options and that "Register Assembly" doesn't handle COM Interop registration?
Gordon.
Gordon Scott
www.cil-uk.co.uk
www.cooled.com
GordonS
Post by GordonS »
:oops: Oh yes. Of course there is!
I just install the programs where I expect them and call them as I want.
I read elsewhere that AI/MSI won't let me overwrite files I shouldn't, so that should all be safe and reliable.
G.
Gordon Scott
www.cil-uk.co.uk
www.cooled.com
