Changing INI Files
DanielW
Changing INI Files
Postby DanielW » Wed Feb 28, 2007 3:59 pm
Is there a way to update "ini" files in the InstallAware software?
nanashi16
Re: Changing INI Files
Postby nanashi16 » Wed Feb 28, 2007 4:03 pm
DanielW wrote:Is there a way to update "ini" files in the InstallAware software?
Yes, in the code section their is an edit ini.
DanielW
Postby DanielW » Wed Feb 28, 2007 4:10 pm
That is great! Thanks for the feedback.
DanielW
Postby DanielW » Thu Mar 01, 2007 1:33 pm
If I could get it to work, that would also be great.
I have input the "Get INI files" Settings: Added plugin in the code and no changes occur in the ini file. Is there a certain place to place the code to make it work?
Note: This is a new ini file that I am adding to the system and making a change after it is installed, I hope.
Gunter
Postby Gunter » Mon Mar 05, 2007 10:08 am
Afaik this "Get INI file" command is only executed on a "Apply Install", not on the very line in the script.
Users browsing this forum: No registered users and 110 guests
