Gauge - works only in range 0->100
jweksej
Post by jweksej »
Dialog editor allows to set min/max values in any range and in test mode it works properly. However installer assumes min/max as 0->100 and works this way. Am i right?
neillans
Post by neillans »
Normally yes - however, you can actually control the position of the progress bar manually in the script, so you can set the Max to 1000 and manually set the position to 100 (and not fill the bar totally).
I hope that makes sense ;)
Andy Neillans
jweksej
Post by jweksej »
this is what I'm doing
and the bar is filled totally
Simple check it.
neillans
Post by neillans »
Are you, by chance, using the built in PROGRESS variable? This is limited to a max of 100.
Andy Neillans
