missing Automation\\Web Support folder?
dkurth
Post by dkurth »
In the InstallAware help, the Automation Overview says:
"If you do not have IIS installed, [you will find Automation sample code] inside the Automation\\Web Support folder in your InstallAware installation folder."
I don't have IIS installed, but my Automation folder contains 2 subfolders, Examples and Libraries. Examples contains a Delphi folder.
Anyone know where I can find the Web Support folder/web automation example files? Thanks!
ckaware
Re: missing Automation\\Web Support folder?
Post by ckaware »
It's missing from my Studio Admin 2012 installation too.
The folder should be:
C:\Program Files (x86)\InstallAware\InstallAware 2012\Automation
Maybe ... Check if you installed the feature.
