Error trying to build using miaBuildProjectEx
mhamaoka
Post by mhamaoka »
I am trying to build a setup using the automation interface. I built a simple script and am trying to build it using miaBuildProjectEx, but I keep getting the following error message:
Error during build: Cannot open file "C:\\WINDOWS\\system32\\interop\\ulteriormiastub.exe". The system cannot find the path specified
The .mpr file builds fine if I build it from the IDE or from the command line interface using miabuild.exe.
Can you help? Thanks!
neillans
Post by neillans »
Hi there,
Can you give us some more information?
Such as how are you calling the automation objects - is this a website, WSH script etc?
I haven't used the automation objects myself, but if you can provide some more details I'll have a word with the dev team.
Andy Neillans
