Restart Now on finish dialog
djm
Post by djm »
I'm having trouble with the "restart now" checkbox on the template finish dialog.
Enter the dialog and the Object rules define the checkbox to be checked if SUCCESS=REBOOT (which it is), but I'm unable to UNCHECK that checkbox.
How can I default the Restart Now checkbox to checked, but still have it be uncheckable?
djm
Post by djm »
Nevermind, I had an object rule that said if the incoming SUCCESS=REBOOT then check the box. Bad idea. That will force the check no matter what you do, like uncheck. I had to adjust ONLY the incoming var that the object was referenced to.
