I have installed InstallAware Express on Windows Vista Ultimate. When running the application, I get the abovementioned error message. Although the application continue to open after clicking "OK", I am not able to work since the "Application Information" window remains the active window, even when selecting a different node from the tree. I also receive the same error message when clicking on "Help"->"Licensing".
Any ideas how to resolve this error?
Ian.
Invalid class string, ProgID: \"eSellerateControl.350\"
My previous attempt (downloading the latest version) was done using the "Web Based Download" (the +-9MB installation). I have now downloaded the "Single File Download" (the +- 250MB installation), and reinstalled IA Express. The problem has been resolved.
It appears that the two installations do not install the same version.
Thanks for your replies.
Ian.
Ian.
Exactly the same problem here.
I have got the exact same problem:
Symptoms are:
During startup of Installaware ( at the splash screen ) i get a message box
"Invalid class string, ProgID: "eSellerateControl.350"
After that IA starts but the splash screen stays in the background and all "Tabs" or whatever you call them stay locked, meaning when i create a new project i cant' show the pages for any of them ( e.g Summary Information,Files,Registry and so on )
Basically IA is unusable at this point.
My setup: Vista Ultimate with all Updates,
IA: InstallAware Version 6.4 (Build santacruz_sp2.031207)
Installed from the "Full" 250 MB installer ( Not the web version )
I tried running it as administrator, in WinXP SP2 Compatiblity mode, to no avail...
Anyone got a clue ?
Symptoms are:
Anyone got a clue ?
Try installing WiXAware - that should help.
So far we've been unable to figure out what causes the conflict on the user systems where this problem is experienced. Sorry!
Maybe if you could provide more details on what's installed on your system, if the same issue occurs on clean machinls, and so on, we can find out more.
Users browsing this forum: Google [Bot] and 98 guests
