SQL Server Errors
kjburkhardt
SQL Server Errors
Post by kjburkhardt »
I'm evaluating Installaware (and like it a lot) except for the problem it's having with SQL Server. Even when I run the sample code it can't find my SQL Server Installation (Management Studio Express v. 9.00.2047.00).
When I try to execute even a short script it hangs. Are these known issues? Is there a workaround or product update that would help me? As I'm trying to write an installer for both parts of a client-server application this is a critical issues. Is there help?
Gizm0
Post by Gizm0 »
What is your problem exactly?Can we have the sample sql script you're trying to run?What do you mean by "it hangs?"
Panagiotis Kefalidis
Software Design Team Lead
kjburkhardt
SQL Server Errors
By hangs -- the script will appear to load but then the screen and cursor freezes and I need to shut down the program. Also, I know I have a functional SQL Server installation, but the packaged script that is in the sample directory does not find the server. Sorry I'm not at my computer today so I can't send you a script, but it's one that works in SQL. Thanks for your assistance!
Gizm0
Post by Gizm0 »
I'll be waiting for your script, to make a test and try to find out what it might be going wrong.
