vista ADO msjro.dll
linuxbox
vista ADO msjro.dll
Post by linuxbox »
the file msjro.dll is giving me headaches upon install. it's no problem with win2k and xp but for Vista i get the following error:
Error:
Module c:\\program files\\common files\\system\\ado\\msjro.dll failed to register.
HRESULT -2147024770.
i know vista comes with this file already installed. i'm also 99 percent certain this is a self registering dll file. i just don't understand why my installaware program cannot install and register this file.
it installs fine when i uncheck "file is self registering DLL"
but if i leave self registering checked it fails...but ONLY on Vista...i know it's a self registering dll...
any thoughts or help on this?
Gizm0
Post by Gizm0 »
Does it work by hand?If you try to register the dll by hand?
Panagiotis Kefalidis
Software Design Team Lead
linuxbox
no
Post by linuxbox »
Gizm0 wrote:Does it work by hand?If you try to register the dll by hand?
I do not believe that it does actually...
i'm going to try to use this:
Install Files C:\\Program Files\\Common Files\\System\\ado\\msjro.dll to $COMMONFILES$\\System\\ado (Permanent, Never Overwrite)
Register Library $COMMONFILES$\\System\\ado\\msjro.dll
i have a virtual machine running vista so i will try this and report back..
linuxbox
owner
Post by linuxbox »
well, it looks like vista sets the owner of this file to "TrustedInstaller" and it's in: program files\\common files\\system\\ado
i took ownership of the file and deleted it but my installaware setup file would not copy the file...i didn't get any errors but it would not copy. now i do not know how to give the ownership BACK to TrustedInstaller because that user is not listed. Vista is just a mess in my opinion. i see no good in it at all.
