Compression level from miabuild.exe
There doesn't appear to be an option to control compression level from the miabuild.exe command-line. Is that the case?
It would be a handy configure option to allow the setting of the compression level from the command line. You can develop a project in the IDE and then release it to build/qa automation and allow command-line options to be passed to build a faster test build with less compression or a slower fully compressed release build.
Re: Compression level from miabuild.exe
+1 for such a feature.
I'll send a note to our dev team.
Thanks!
Thanks!
Users browsing this forum: No registered users and 216 guests
