I have an install project that worked fine until this evening. I have created many installs today, and until now it was working correctly.
When I try to run the created setup program, I get the following error for one or more files:
Error
Error reading from file: D:\\Win_Temp\\mia71.tmp\\data\\OFFLINE\\IFEPMTOULNNSDAEBIAARDETGEIFFFF0\\filename Verify that the file exists and that you can access it.
The actual location of the file the installer is looking for is: D:\\Win_Temp\\mia71.tmp\\setup_project\\Release\\Single\\data\\OFFLINE\\IFEPMTOULNNSDAEBIAARDETGEIFFFF0\\filename
Unfortunately this can only be reprodued on a customers machine. I tried to reproduce this behaviour by myself - without any success. Currently this is the only one installation - if I get more customers with this problem, I will post again.
