.NET installer Class sometimes not running
++good
Post by ++good »
I am using a .NET installer class to install a .NET windows service and a custom event log.
InstallAware code:
else
    Create Folder $TARGETDIR$\\lib
    Run .NET Installer Class $TARGETDIR$\\Some.Service.exe
This works most of the time, but sometime the service and event log are not installed. There is no error in the Windows eventlog and the InstallAware install finishes normally. It is as if the .NET installer was never ran. I've only noticed this twice in the 100 or so test installs I've done, but it seems to be happening more often with my customers.
Has anyone else experienced this? Any idea what might be causing it?
Marcus
