I'm new to creating MSI Installers, so this is probably a very simple question. I have used the PackageAware tool to monitor systemwide changes for an Adobe Reader Installation.
I'm looking to possibly deploy this file across an active directory based network - therefore I would like this to install itself; with no user interaction. Could someone please explain how to do this? Currently I am seeing that it is requiring user interaction (IE- having to accept a EULA, specify install location, etc..)
Thanks in advanced!
MSI Auto-Install
Version 6 http://www.appdeploy.com/packages/detail.asp?id=171
Version 7 http://www.appdeploy.com/packages/detail.asp?id=404
Basically you do not need InstallAware to build anything as Adobe provides it for you.
Rgds John
Rgds John
