1. Is there any way to make InstallAware remember the last folder browsed to via "Browse Files" dialog? It's annoying that it always makes you start browsing again from the top.
2. Script editor has no undo-- Is this planned for future editions?
3. Is there a way to make the build progress window stick around on successful build? Is there a log file getting output somewhere?
4. How do I get rid of the Release\\Single part of the output folder path?
5. In order to use localized EULAS, one must add support files of the form license.[LANGUAGE].rtf -- is this all that is needed? What should be set for the EULA text on the EULA screen? Should I load the english version of the file, load nothing at all ... ?
thanks
Amar
