I recently converted to InstallAware and want to use it to uninstall applications that were initially installed using Wise Installer. I understood that the Wise upgrade code was equivalent to InstallAware's Product Code, but when I make the Product Code the same as the upgrade code, the old application is not uninstalled prior to installation using InstallAware.
I searched the registry for the upgrade code that was listed in the Wise tables, but no match was found, even though the program was still installed.
Please advise what I need to do to have the InstallAware setup remove the old Wise setup when I do an upgrade of the application.
Uninstallation of Wise setups
Try it this way:
http://forums.installaware.com/viewtopic.php?t=1237
Martin Rothschink
AxoNet Software GmbH
Unistallation of Wise Setups
Thank you so much for the link to the plug-in. That did the trick!
I had thought that I should use the Wise Upgrade Code as the InstallAware Product Code, but that just caused more problems. The plug-in allowed me to uninstall the Wise setup using the Upgrade Code that was entered in the plug-in parameter box, but I had to make sure that the InstallAware Product Code was a new unique GUID. Once I did that, it worked like a charm on all previous versions of the application.
Users browsing this forum: No registered users and 105 guests
