The help file regarding Batch Building sais:
A batch build is essentially the same as a regular build. However, the product code does not change in between batch builds (even if it is enabled in your settings)…….
Is this correct, should it say “Revision Code” instead of “Product Code”?
Batch building documentation (help file)
andreszabelwesky
