Finsished Dialog Box
gencode
Post by gencode »
I purchased Express a couple days ago...and all seems okay on my install...except the Finished Dialog Box has a "check box "Run $TITLE$ now. When run it, it does not start my exe that I just installed...and I am not sure where to set the property to let it know what EXE to run.
Please let me know, Ed,
Use the Run Programs view, and add a new run command set to use the "Finish Dialog" timing.
gencode
Wrong startup dir - \"Finish Dialog\" timing.
Post by gencode »
Well I did that and it "almost worked"....I say almost because when it tries to start my application my program does not start seem to run from the $TARGET$ directory, I think it is actually running from the install directory because it launches and gives me errors trying to open my files like local mdb's etc that are in my target directory, it cant find them.
So the next question is how do I get the Run Programs to use the $TARGET$ as the "Start InFolder" just like the Shortcuts do.
BTW: The shortcuts work fine, just the TRun Programs does not.
Thanks again, Ed,
In that case, you need to use the Run Program As command, and specify the startup folder explicitly in the command. You do need access to the MSIcode view for this.
gencode
Do you mean
Post by gencode »
Do you mean
make the Command Line Paramaters line say
$TARGETDIR$\\myapp.exe
and make the Run Program empty
I dont think you are saying put in Command Line Paramaters
c:\\program files\\company\\myapp.exe
because there program files could be in the d:
Ed,
gencode
It did not work :(
Post by gencode »
Well I tried it, I put $TARGETDIR$\\myapp.exe
as a Command Line Paramater
and it did not work....all it did is open the temp folder with the MSI
Is there no way to get this thing to run from the target directory...if not then that makes the last check box "Run Program" kinda usless
gencode
Post by gencode »
How do I do this?
I dont see it anywhere on my menu items.
gencode
MSI Code requires upgrade?
Post by gencode »
You said that I need to access the MSI Code, but when I click on the tab I get a message to upgrade...is there no way to get this last box to run my program from teh working folder? If not then then that check box to run the program should not be there, most apps use some resource from their working directory.
Please let me know if there is a way to fix this bug without upgrading.
Thanks, Ed,
This isn't a bug with InstallAware, but your program. If your program requires access to files in its own folder, it should be smart enough to read those files from its own folder, and not assume that an "empty path" always points to its own folder - it may not, especially when the program is run from another startup location. Any user could create a shortcut to your program from another startup location, or start it from the command line from another path, so this will come back and bite you later if you don't fix it now anyways.
And no, I'm afraid you can only edit dialogs with InstallAware Studio, and you can only access scripting with InstallAware Developer. I do apologize for the inconvenience...I will put in a feature request that the Run Programs view emit Run Program As instead of Run Program commands, but please be aware this isn't a bug in InstallAware, its a bug in your own program.
gencode
all is good now...thanks again!
Post by gencode »
Thanks Michael...
Well I actually did set my app to read the app dir in my code...so at least I thought...but there was a bug in "my code"
At the place in question I was using the
Directory.GetCurrentDirectory();
Not the
Assembly.GetExecutingAssembly().Location
So that was the issue...I know you said that I need to use the MSIcode scripting but really I did not know where that was since like I said I had it only a couple days...please bear with me I am new using this product...thanks again for the quick response...and I have learned a little more...maybe I just need to upgrade since I think I will want to be editing these boxes at one time...all is good now...thanks again!
