When installing on Vista the variable %SystemDrive% is not resolved to the drive. We use:
Get Folder Location WWW->WWWRoot into WWWROOTDIR
which becomes "%SystemDrive%\\Inetpub\\wwwroot" on Vista but not on XP/2003.
Do you have any solution to this?
- Manso
SystemDrive on Vista
Use the Extract Path command on the Windows path to obtain the drive.
The problem is that WWW->WWWRoot returns %SystemDrive% embedded in the path.
The registry key
HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\InetStp\\PathWWWRoot
is %SystemDrive%\\inetpub\\wwwroot on Vista and C:\\Inetpub\\wwwroot on pre-Vista versions and apparently InstallAware and/or MSI doesn't like that.
Is this something you can fix or look into? The workaround is a bit tricky as we can't work out the drive to do a string replacement.
- Manso[/b]
The registry key
- Manso[/b]
How about doing a substitution of the environment variable, using the Get Variable command?
Users browsing this forum: No registered users and 111 guests
