UNC Paths corrupted when passed to RUN PROGRAM command
JeffryPaul
Postby JeffryPaul » Tue Apr 03, 2007 2:08 pm
When I use the RUN PROGRAM command and pass a parameter that is a UNC path (\\\\servername\\sharepointname), the leading \\ character is eliminated.
For example: RUN COMMAND SETUP.EXE "VAR1=\\\\SERVER1\\MYAPPS"
Within Setup.exe, the VAR1 parameter is passed as \\SERVER1\\MYAPPS
Another post, http://forums.installaware.com/viewtopic.php?t=1267 also mentions this same issue, but the workaround provided is unacceptable since I don't know whether the user will browse to a local drive, mapped drive, or UNC path.
Does anyone have a different workaround?
JeffryPaul
Postby JeffryPaul » Tue Apr 03, 2007 2:41 pm
As a workaround, I am using the following steps:
Set Variable CommandLine to $CMDLINE$
If $COMMANDLINE$ Contains "VAR1="
Set Variable VAR1 to $VAR1$
Parse VAR1 into String1 and String2 (at index 1)
If $String1$ equals \Set Variable VAR1 to \\$VAR1$
End
End
This bug has been around for 6 months. Will it be included in the next update?
Users browsing this forum: Baidu [Spider] and 43 guests
