Blank screen on SQL Express 2005 SP2 installation
When SQL Express SP2 is installing, there is no UI on the screen at all. The installer just goes blank for 15 minutes or so and suddenly pop up again to resume installation. How can i over come this, as most user would try to run the installer again when actually SQL Express is installing on the background!
Sorry for posting twice, suddenly i thought this issure needed it's own thread. Anyway i dont have any scripts because i am using InstallAware6 Express. The version is : Version 6.4 (Build santacruz_sp2.031207)
Please just try it for yourself with the InstallAware Express editon, you will see what I mean. Do i really have to purchase the InstallAware Developer with scripting support just to overcome this small problem??? Please advise, thanks man...
Hello Neillans!!! Here are my project files and it's scripts to speed up your testing
. What is the current IA version and edition you are using that does not have this problem?
XeusSetup.zip
XeusSetup.zip
Users browsing this forum: No registered users and 116 guests
