Putting InstallAware projects under version control.
kamiller42
Postby kamiller42 » Thu Apr 05, 2007 12:49 pm
If I want to version control my InstallAware project, what is the minimum set of files I need to version control? By minimum, I mean any install plans and scripts I create. Just the mpr and mia files?
Is there a plug-in to add version control management to InstallAware?
neillans
Postby neillans » Fri Apr 06, 2007 3:44 am
At present there is no builtin (or plugin) support for easy version control - however, it's a good suggestion - what VCS are you using?
The minimum you should store are:
- MPR
- MIA
- DFM
- DFM.MIAF
Everything else should be regenerated when you load / build the project.
If you are using any custom plugins, you might want to document those so your developers are aware they need to install them first.
Andy Neillans
MarkRichards
Postby MarkRichards » Fri Apr 06, 2007 1:07 pm
We'd really appreciate having integrated source control support as well (using MS Visual SourceSafe here).
kamiller42
Postby kamiller42 » Sun Apr 08, 2007 1:51 am
neillans, thank you!
MarkRichards, I agree. It seems one thing InstallShield offers that InstallAware does not seem to. (Using Subversion here.)
Users browsing this forum: Bing [Bot] and 79 guests
