Comparing projects?
AndrewC
Comparing projects?
Post by AndrewC »
A recent post talked about using version control systems, which I too would like to do at some point. But a common need in version control is to be able to identify exactly what has changed, so this requires a diff tool to be able to be used. Is there a way to export an IA script to a text format for diff purposes?
neillans
Post by neillans »
At present there is no support for this, however, if we get enough people requesting it we will probably add it.
However, as the script files are text based (but in a specific custom syntax / format), you can (sort of) already perform a diff on them.
Andy Neillans
