I wish to create a prerequsite I did mention in another topic.
I wish to make some extra prerequisits for components that our applications use so we don't have to include them into the main web download.
I belive that you can create a MSI which does the installation but how do you get install aware to recognise this as a prerequisite in the normal listing.
Also I would need to define dependant packages as well I presume?
Creating PreRequisites
Pre-req creation is fairly straight forward.
First, start off with your installer for your component - either exe or msi.
Then, have a look in your InstallAware installation directory - there is a directory called runtimes. All the pre-requisites that IA knows about are located in here.
They consist of:
Files (in a folder)
check script (mia file)
setup script (mia file)
"Details" for IA (rtm file)
A good example of the process is detailed here:
http://forums.installaware.com/viewtopic.php?t=1096
Hope this helps!
They consist of:
Files (in a folder)
Hope this helps!
Andy Neillans
Re: Creating PreRequisites
There is also a white paper available on how to create your own prereq package. Check on the main website.
Panagiotis Kefalidis
Software Design Team Lead
Users browsing this forum: Majestic-12 [Bot] and 147 guests
