Masked Edit Control
Superfreak3
Masked Edit Control
Post by Superfreak3 »
I need to add a Masked Edit control to a dialog I'm creating to accept serial numbers and the like. I think I have the first one I need to behave properly in that is to accept 8 numbers. My mask seems to work if I use either ######## or <########>.
In the actual control, it appears underscores to the length I'm looking for appear when I test it. Is there any way to prevent the underscore from displaying? I looked at the attributes of the control, but can't seem to pinpoint anything in particular that is causing this.
Does anyone know the correct mask for what can be a combination of numbers and/or letters? Is it ^^^^^^ useage for example?
Also, how then do I set this input to a Property. Do I have to use a Set Property action to set MaskEdit1 to $APP_SERIAL_NUMBER$?
Any help appreciated!
Superfreak3
I think I found the mask for alphanumerics placeholders - A.
I still need to know how to set whatever is set in my edit control to a property.
Also, in InstallShield and/or Wise, if I use an edit mask <^^^^^^^=^^^^^^^^>. This will actually break the control into two imput areas or fields (= character causes this). Is there any way to mimic this in InstallAware?
Superfreak3
I think I found the mask for alphanumerics placeholders - A. If I use, let's say AAAAAAAAAAAAAAA as the mask, it appears I can enter alphanumeric characters. The alphas are all lower case though. Is there a way around that as I'm not sure if our authorization codes will only/always have lower case alphas?
Superfreak3
Superfreak3 wrote:I think I found the mask for alphanumerics placeholders - A. If I use, let's say AAAAAAAAAAAAAAA as the mask, it appears I can enter alphanumeric characters. The alphas are all lower case though. Is there a way around that as I'm not sure if our authorization codes will only/always have lower case alphas?
If I use aaaaaaaaaaaaaaa, it appears I can then enter upper and lower case alphas as well as numerics. That was easy! :D
